Replace HP Z820 GPU.
  1. Replace HP Z820 GPU., Opening the PC case: step 1, image 1 of 2 Replace HP Z820 GPU., Opening the PC case: step 1, image 2 of 2
    • First, pull the handle and raise the upper part of the case.
    • Make sure that you have unlocked the lock that is located close to the handle.
    • After taking the upper part off, you'll see the covers of the different pieces of the PC.
  2. Replace HP Z820 GPU., Opening the GPU compartment: step 2, image 1 of 3 Replace HP Z820 GPU., Opening the GPU compartment: step 2, image 2 of 3 Replace HP Z820 GPU., Opening the GPU compartment: step 2, image 3 of 3
    • Raise the cover of the left lower side.
  3. Replace HP Z820 GPU., GPU with guide: step 3, image 1 of 1
    • This PC has a full-sized GPU with a guide that fits the GPU in the case. That allows you to avoid physicall damages on the GPU.
    • The GPU has a guide. It's necessary to pay attention and don't forget about it while taking the GPU off.
  4. Replace HP Z820 GPU., GPU Removal, Part 1: step 4, image 1 of 2 Replace HP Z820 GPU., GPU Removal, Part 1: step 4, image 2 of 2
    • Disconnect the power connector from the GPU.
    • You can clip the connectors in a specifically designed place.
    • Raise the rod that maintains the PCI GPU in place.
  5. Replace HP Z820 GPU., GPU Removal, Part 2: step 5, image 1 of 3 Replace HP Z820 GPU., GPU Removal, Part 2: step 5, image 2 of 3 Replace HP Z820 GPU., GPU Removal, Part 2: step 5, image 3 of 3
    • The first two steps must be performed simultaneously. If you release the tab, it returns to its previous position.
    • Raise the tab that maintains the GPU in its port.
    • Raise the GPU slowly from the side of the guide until the GPU partially comes out of its port.
    • Raise the GPU from its other side.
  6. Replace HP Z820 GPU., Installation using the guide: step 6, image 1 of 3 Replace HP Z820 GPU., Installation using the guide: step 6, image 2 of 3 Replace HP Z820 GPU., Installation using the guide: step 6, image 3 of 3
    • If your GPU has no guide, you can go to the next step.
    • Introduce the new GPU at 45º from the motherboard.
    • Pay attention and avoid damaging the motherboard during the insertion.
    • Place the guide in front of the appropriate slot and push the graphics card into it, making sure it fits into its PCI slot.
    • To check that your graphics card is correctly installed, check that the tab is properly locked in place.
    • Don't forget to connect the power supply cables of the GPU if it's necessary.
  7. Replace HP Z820 GPU., Installation without guide: step 7, image 1 of 2 Replace HP Z820 GPU., Installation without guide: step 7, image 2 of 2
    • Insert the graphics card into the PCI bracket until it clicks into place.
    • Don't forget to connect the power supply connectors to the GPU if it's necessary.
  8. Replace HP Z820 GPU., Case's particularity: step 8, image 1 of 2 Replace HP Z820 GPU., Case's particularity: step 8, image 2 of 2
    • The Sapphire RX 5700XT GPU is the largest card that fits in the case without problems.
    • Maximum GPU height: 11cm.
    • As it's already explained, the case has special spots for clipping the unused power supply ports.
The reinstallation stages are included in the tutorial.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Hyperion
2,074 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 32
All Time: 1,851
