Replace or add RAM
  1. Replace or add RAM, removal of bottom case: step 1, image 1 of 2 Replace or add RAM, removal of bottom case: step 1, image 2 of 2
    • remove the feet with a spudger
  2. Replace or add RAM: step 2, image 1 of 2 Replace or add RAM: step 2, image 2 of 2
    • Remove the 11 screw with a PH0 screwdriver.
    • The screws are identical
  3. Replace or add RAM: step 3, image 1 of 2 Replace or add RAM: step 3, image 2 of 2
    • Insert a spudger between the bottom cover and the keyboard module, then go around the whole cover to uncip everything.
    • Remove the bottom cover from the computer.
  4. Replace or add RAM: step 4, image 1 of 1
    • You now have acces to the inside of the machine.
  5. Replace or add RAM, RAM: step 5, image 1 of 3 Replace or add RAM, RAM: step 5, image 2 of 3 Replace or add RAM, RAM: step 5, image 3 of 3
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
    • To insert a module, angle it as shown in the third picture, then insert it and push it down until it locks.
To reassemble your device, follow the steps in reverse order.
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
Léo FRAYSSE is helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,379 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,071
