Replace the thermal fuse on a GHD Classic V
  1. Replace the thermal fuse on a GHD Classic V, Thermal fuse: step 1, image 1 of 2 Replace the thermal fuse on a GHD Classic V, Thermal fuse: step 1, image 2 of 2
    • Before you begin, unplug your ghd hair straightener.
    • Remove the two plastic hinge covers located on each side of the ghd by using a thin and flat spudger.
    • The plastic hinge covers are attached via two clips. Be careful not to break the clips.
  2. Replace the thermal fuse on a GHD Classic V: step 2, image 1 of 2 Replace the thermal fuse on a GHD Classic V: step 2, image 2 of 2
    • Unscrew the right side hinge support.
    • Remove the centering tube.
    • If unscrewing proves difficult, try using a Philips screwdriver on both sides of the tube.
  3. Replace the thermal fuse on a GHD Classic V: step 3, image 1 of 1
    • Unscrew both Philips screws to remove the cover.
    • The heat fuse is on the power button's side.
  4. Replace the thermal fuse on a GHD Classic V: step 4, image 1 of 2 Replace the thermal fuse on a GHD Classic V: step 4, image 2 of 2
    • Unscrew the 4 screws from the the plate and then remove it.
    • The outer screws corresponds to the "Fuse" fuse. The center screws corresponds to the ceramic plate fuse.
  5. Replace the thermal fuse on a GHD Classic V: step 5, image 1 of 3 Replace the thermal fuse on a GHD Classic V: step 5, image 2 of 3 Replace the thermal fuse on a GHD Classic V: step 5, image 3 of 3
    • Slowly lift the fuse and cut the two cables with your wire cutter.
    • You can now remove the fuse from its compartment as well as the two cables by pulling on them towards the front.
  6. Replace the thermal fuse on a GHD Classic V: step 6, image 1 of 3 Replace the thermal fuse on a GHD Classic V: step 6, image 2 of 3 Replace the thermal fuse on a GHD Classic V: step 6, image 3 of 3
    • Start by inserting your new fuse's cables and let about a centimeter of slack.
    • Insert the end of the fuse.
    • Pull on both cables outward to completely fit the fuse in its compartment.
  7. Replace the thermal fuse on a GHD Classic V: step 7, image 1 of 1
    • Watch out: the two white cables are screwed in the center; the brown cables are screwed at the outer posts.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Caplou.com
193 Reputation
1 Guide authored
Caplou Member of Caplou
Business
1 Member
2 Guides authored
3 Comments
Thanks for this! I am searching for a suitable fuse replacement, will this one work?
TB05-BB5D-145 (up to 160°C)
https://www.conrad.de/de/p/tb05-bb5d-145...
Francisco - Reply
Bonjour, non ce fusible thermique n'est pas compatible, la température de déclenchement n'est pas la bonne, de plus la taille de celui-ci est trop large et le branchement ne comporte pas les deux connecteurs.
Si vous avez besoin du modèle correct, veuillez nous contacter ici: https://caplou.com
Belle journée
L'équipe Caplou
Caplou.com -
Parfait merci beaucoup il re fonctionne !!!
sourya lasfar - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 105
All Time: 8,828
