Replacement Ram
  1. Replacement Ram, Ram: step 1, image 1 of 1
    • Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
  2. Replacement Ram: step 2, image 1 of 1
    • After removing the screw, using your finger slowly lift out and remove the cover.
  3. Replacement Ram: step 3, image 1 of 3 Replacement Ram: step 3, image 2 of 3 Replacement Ram: step 3, image 3 of 3
    • Lift the flap
    • Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
    • The ram is to be removed at a 45 degree angle.
  4. Replacement Ram: step 4, image 1 of 1
    • Pull out cleanly and you have now successfully removed the ram.
Eric Martinez
637 Reputation
6 Guides authored
USF Tampa, Team 20-5, Remmell Spring 2017 Member of USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 358
