Replacement of the Jack port on the Dell XPS 13 9380
  1. Replacement of the Jack port on the Dell XPS 13 9380, Remove the back panel: step 1, image 1 of 3 Replacement of the Jack port on the Dell XPS 13 9380, Remove the back panel: step 1, image 2 of 3 Replacement of the Jack port on the Dell XPS 13 9380, Remove the back panel: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the Jack port on the Dell XPS 13 9380, Remove the battery: step 2, image 1 of 2 Replacement of the Jack port on the Dell XPS 13 9380, Remove the battery: step 2, image 2 of 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the Jack port on the Dell XPS 13 9380, Port Jack: step 3, image 1 of 3 Replacement of the Jack port on the Dell XPS 13 9380, Port Jack: step 3, image 2 of 3 Replacement of the Jack port on the Dell XPS 13 9380, Port Jack: step 3, image 3 of 3
    • 1- Remove the two screws (M2.5 x 4) that fix the left hinge.
    • 2- Place the back of the computer screen on a clean and flat surface, then open and close the computer.
    • 3- Disconnect the cable from the Jack port of the motherboard.
    • 4- Remove the screw (M1,6x3) that fixes the jack port.
    • 5- Remove the Jack port.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
4,844 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
One Comment
Where did you get the replacement part?
Todd Resudek - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 1,506
