Replacement of the back panel on Dell XPS 13 9380
  1. Replacement of the back panel on Dell XPS 13 9380, Remove the back panel: step 1, image 1 of 3 Replacement of the back panel on Dell XPS 13 9380, Remove the back panel: step 1, image 2 of 3 Replacement of the back panel on Dell XPS 13 9380, Remove the back panel: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
5,029 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
One Comment
The torx bit used is a T5, the screw is an m2x3 — if you’re buying a kit you want the T5 torx bit
swosse - Reply
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 40
All Time: 4,759
