Replacement of the ventirad on the Dell XPS 13 9380
  1. Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: step 1, image 1 of 3 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: step 1, image 2 of 3 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: step 2, image 1 of 2 Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: step 2, image 2 of 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the ventirad on the Dell XPS 13 9380, Remove the ventirad: step 3, image 1 of 1
    • We removed or disconnected the battery to avoid any electrical discharge.
    • To ensure maximum processor cooling, do not touch the heat transfer areas of the ventirad. Grease on the fingers can reduce the heat transfer capabilities of the thermal paste
    • 1- Remove the 4 screws (M2x3) that attach the ventirad to the motherboard.
    • 2- Lift the ventirad and remove it from the motherboard.
To reassemble your device, follow the instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
4,886 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,228
