Replacing Antenna on Realistic Weatheradio
  1. Replacing Antenna on Realistic Weatheradio, Antenna: step 1, image 1 of 1
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: step 2, image 1 of 1
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: step 3, image 1 of 2 Replacing Antenna on Realistic Weatheradio: step 3, image 2 of 2
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
After following these steps, the Realistic Weatheradio should be able to work and function normally.
2 other people completed this guide.
Attached Documents
Matthew
136 Reputation
1 Guide authored
Texas Tech, Team 3-5, Rauch SU 2015 Member of Texas Tech, Team 3-5, Rauch SU 2015
TTU-RAUCH-SU15S3G5
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 903
