Replacing Atari Lynx Speaker
  1. Replacing Atari Lynx Speaker, Atari Lynx: step 1, image 1 of 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: step 2, image 1 of 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: step 3, image 1 of 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: step 4, image 1 of 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: step 5, image 1 of 2 Replacing Atari Lynx Speaker, Speaker: step 5, image 2 of 2
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: step 6, image 1 of 2 Replacing Atari Lynx Speaker: step 6, image 2 of 2
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
4 other people completed this guide.
Tyler Williams
354 Reputation
2 Guides authored
Cal Poly, Team 1-42, Maness Winter 2014 Member of Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Members
16 Guides authored
2 Comments
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Reply
What are the specs on the speaker? Size? Wattage?
gregory draudt - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,559
