Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: step 1, image 1 of 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 2, image 1 of 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 2, image 2 of 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 2, image 3 of 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 3, image 1 of 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 3, image 2 of 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 4, image 1 of 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 4, image 2 of 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 5, image 1 of 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 5, image 2 of 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 6, image 1 of 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: step 6, image 2 of 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Finish Line
0 Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 69
All Time: 4,045
