Replacing Creative Zen X-Fi Battery
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 1 of 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 2 of 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 3 of 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: step 2, image 1 of 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: step 3, image 1 of 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: step 4, image 1 of 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: step 5, image 1 of 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: step 6, image 1 of 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: step 7, image 1 of 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: step 8, image 1 of 1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: step 9, image 1 of 2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: step 9, image 2 of 2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    Bien can obtein The battery?
    alemray - Reply
5 other people completed this guide.
Westley Courchene
3,410 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
14 Guides authored
One Comment
very clear pictures!
John - Reply
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 58
All Time: 7,381
