Replacing LG X Power 2 (LG-M320N) Screen Assembly
  1. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Opening and removing the rear cover: step 1, image 1 of 2 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Opening and removing the rear cover: step 1, image 2 of 2
    • Remove the back cover by prying it off with a fine tool (I used a screwdriver).
    • Just below the camera, there is another tab that holds the lid. Remove with care.
  2. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Opening and removing the intermediate lid: step 2, image 1 of 3 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Opening and removing the intermediate lid: step 2, image 2 of 3 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Opening and removing the intermediate lid: step 2, image 3 of 3
    • Remove the sim/mic tray and the 13 screw that hold the intermediate cover to the screen frame.
    • With a thin tool, pull apart the screen cover, inserting it with care.
    • Once slightly pulled apart, you can continue separating it, using a nail or the spudger.
  3. Replacing LG X Power 2 (LG-M320N) Screen Assembly, DIsconnecting the battery: step 3, image 1 of 1
    • Disconnect the battery flex and remove it.
    • The battery is attached. In my case, it didn't give much resistance and I could take it out with any problems. Even so, I recommend using a heat source (microwave preheated gel or a hair dryer).
  4. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Disconnecting the screen and camera from the motherboard: step 4, image 1 of 3 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Disconnecting the screen and camera from the motherboard: step 4, image 2 of 3 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Disconnecting the screen and camera from the motherboard: step 4, image 3 of 3
    • Disconnect the flex cable for the bottom screen.
    • Optionally, you can extract the cameras. I took them out for greater ease.
  5. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Removing the motherboard: step 5, image 1 of 2 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Removing the motherboard: step 5, image 2 of 2
    • Now that the motherboard has been released from the easily removable components, pick it up lightly by the side of the USB connector
    • Once you've picked it up, take it by hand and pull it slightly upwards to the left.
  6. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Transferring original frame components: step 6, image 1 of 2 Replacing LG X Power 2 (LG-M320N) Screen Assembly, Transferring original frame components: step 6, image 2 of 2
    • Move the remaining pieces from the old frame to the new frame.
    • - 2 flex cables (on button + speaker connector). Marked with red squares
    • - 2 rubber bands (main mic + noise-cancelling mic). Marked with lilac circles
    • - Vibrator. Marked with a red square
    • front flashlight. Marked with a lilac circle
    • Handset. Marked with a red square
    • For ease: metal mesh above the screen flex (green square) and humidity indicator sticker (lilac circle). I've passed them.
    • Some of these components are glued. Be careful.
  7. Replacing LG X Power 2 (LG-M320N) Screen Assembly, Final assembly: step 7, image 1 of 1
    • Once you have placed all the components into the new frame, proceed with the previous steps in reverse to reassemble the cell phone
    • Filler image
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Miguel Cretu
373 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 793
