Replacing Motorola V60i Logic Board
  1. Replacing Motorola V60i Logic Board, Battery: step 1, image 1 of 2 Replacing Motorola V60i Logic Board, Battery: step 1, image 2 of 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: step 2, image 1 of 2 Replacing Motorola V60i Logic Board: step 2, image 2 of 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: step 3, image 1 of 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: step 4, image 1 of 2 Replacing Motorola V60i Logic Board: step 4, image 2 of 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: step 5, image 1 of 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: step 6, image 1 of 1
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: step 7, image 1 of 2 Replacing Motorola V60i Logic Board: step 7, image 2 of 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Elizabeth OBrien
43 Reputation
7 Guides authored
Cal Poly, Team 30-40, Garner Spring 2010 Member of Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Members
19 Guides authored
One Comment
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 11
All Time: 2,211
