Replacing Nintendo DS Battery
  1. Replacing Nintendo DS Battery, Battery: step 1, image 1 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 2 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 3 of 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Replacing Nintendo DS Battery: step 2, image 1 of 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Replacing Nintendo DS Battery: step 3, image 1 of 1
    • Remove the battery from the Nintendo DS.
Make sure to press the power button on the Nintendo DS when finished to confirm the battery is working.
12 other people completed this guide.
dnguye26
746 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
31 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 115
Past 30 Days: 459
All Time: 33,997
