Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock
  1. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock, Locate the Battery/Memory Card Cover Lock.: step 1, image 1 of 1
    • Turn the camera so the bottom is facing upwards.
  2. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: step 2, image 1 of 1
    • First pull open latch to expose two screws covering lock.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: step 3, image 1 of 1
    • Remove the small black lock.
  4. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: step 4, image 1 of 1
    • Turn latch over.
    • There will be one screw visible holding down the cover.
    • Unscrew single screw with your Phillips #00 screwdriver.
  5. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use your tweezers for this step.
    • After unscrewing the screw you will see a single spring.
    • Make sure spring is in place to be able to close lock properly.
Shannon Cooney
355 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 986
