Replacing Sanyo VPC-X1200 Rear Buttons
  1. Replacing Sanyo VPC-X1200 Rear Buttons, Back Case: step 1, image 1 of 3 Replacing Sanyo VPC-X1200 Rear Buttons, Back Case: step 1, image 2 of 3 Replacing Sanyo VPC-X1200 Rear Buttons, Back Case: step 1, image 3 of 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Replacing Sanyo VPC-X1200 Rear Buttons: step 2, image 1 of 1
    • Gently lift up the back cover and set aside.
  3. Replacing Sanyo VPC-X1200 Rear Buttons, Rear Buttons: step 3, image 1 of 1
    • Use small plastic pry tool to gently remove rear button plate.
    • A heat gun may be used to soften the glue for easier removal.
Anthony Giardina
20 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,423
