Replacing VTech MobiGo Touch Learning System Speaker
  1. Replacing VTech MobiGo Touch Learning System Speaker, Case: step 1, image 1 of 1
    • Remove the battery covers and the four batteries.
  2. Replacing VTech MobiGo Touch Learning System Speaker: step 2, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker: step 2, image 2 of 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Replacing VTech MobiGo Touch Learning System Speaker: step 3, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker: step 3, image 2 of 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: step 4, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: step 4, image 2 of 2
    • The speaker will be attached to the back of the case.
    • Unscrew the two 6.0 mm Philips J0 screws.
    • Careful! The wires are still attached to the back of the case and to the speakers.
  5. Replacing VTech MobiGo Touch Learning System Speaker: step 5, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker: step 5, image 2 of 2
    • Lift the round speaker with a plastic opening tool.
    • Remove the two wires connected to the speaker.
    • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
    • Once the wires are disconnected, remove the speaker from the back of the case.
  6. Replacing VTech MobiGo Touch Learning System Speaker: step 6, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker: step 6, image 2 of 2
    • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
    • The wires may be hot.
  7. Replacing VTech MobiGo Touch Learning System Speaker: step 7, image 1 of 2 Replacing VTech MobiGo Touch Learning System Speaker: step 7, image 2 of 2
    • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
    • Make sure the speaker is the right size for the panel.
    • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
    • Do not over tighten the screws or the panel will break.
To reassemble your case, follow the case instructions in reverse order.
RBansil
221 Reputation
2 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 52
All Time: 1,907
