Replacing a Sprinkler Extension
  1. Replacing a Sprinkler Extension, Sprinkler Extension: step 1, image 1 of 1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: step 2, image 1 of 1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: step 3, image 1 of 1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: step 4, image 1 of 2 Replacing a Sprinkler Extension: step 4, image 2 of 2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: step 5, image 1 of 1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: step 6, image 1 of 2 Replacing a Sprinkler Extension: step 6, image 2 of 2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
111 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 1,067
