Replacing the Wi-Fi module on why! W253EU
Felice Suglia
Felice Suglia and 2 other contributors
Last updated on October 11, 2022
10 minutes
Easy
Community-Contributed Guide
Better Introduction
  1. Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 1 of 3 Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 2 of 3 Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 3 of 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Replacing the Wi-Fi module on why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 1 of 2 Replacing the Wi-Fi module on why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 2 of 2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Replacing the Wi-Fi module on why! W253EU: step 3, image 1 of 3 Replacing the Wi-Fi module on why! W253EU: step 3, image 2 of 3 Replacing the Wi-Fi module on why! W253EU: step 3, image 3 of 3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Replacing the Wi-Fi module on why! W253EU: step 4, image 1 of 1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. Replacing the Wi-Fi module on why! W253EU, Wi-Fi Module: step 5, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the two screws securing the Wi-Fi module.
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,564 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 253
