Replacing the friction pads
  1. Replacing the friction pads, Open the Throttle: step 1, image 1 of 3 Replacing the friction pads, Open the Throttle: step 1, image 2 of 3 Replacing the friction pads, Open the Throttle: step 1, image 3 of 3
    • Unscrew these 5 screws
    • Remove the metal plate
  2. Replacing the friction pads, Remove the PCB: step 2, image 1 of 3 Replacing the friction pads, Remove the PCB: step 2, image 2 of 3 Replacing the friction pads, Remove the PCB: step 2, image 3 of 3
    • Unscrew the 4 screws, disconnect all the connectors and take off the PCB
    • Remove the 4 screws, disconnect all wires and remove the PCB.
  3. Replacing the friction pads, Remove the screws: step 3, image 1 of 3 Replacing the friction pads, Remove the screws: step 3, image 2 of 3 Replacing the friction pads, Remove the screws: step 3, image 3 of 3
    • Remove 8 screws highlighted on the picture.
  4. Replacing the friction pads, Remove the friction pads: step 4, image 1 of 3 Replacing the friction pads, Remove the friction pads: step 4, image 2 of 3 Replacing the friction pads, Remove the friction pads: step 4, image 3 of 3
    • Push the lever arms to gain access to the friction pads.
    • You can now remove the Friction pads
    • You can now change your friction pads
Reassemble the product by following this procedure in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Avrila
1,362 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 453
