Introduction
The seals/gaskets of any brewing unit are under constant strain. Particularly the large O-Ring on the piston needs replacing from time to time. These instructions show how this is done.
You can push out the lower piston from the brewing unit if you snap the deflection lever out of its socket with a screw driver.
Clean all parts with very hot water and dishwasher liquid.
Grease all moving parts with food grade silicone fat. Dont forget the tracks in the side panels.
Take this opportunity to carefully replace the two O-rings on the support valve. The larger one is at the top. These two seals are stressed during every brewing process. Therefore, lubricate them with food-safe silicone grease.
On some models, the support valve is covered. In this case, you must unscrew the cover first.
Apply these steps in reverse order to re-assemble the device.
4 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
