Retina MacBook 2017 Trackpad Assembly Replacement
  1. Retina MacBook 2017 Trackpad Assembly Replacement, Disable Auto Boot: step 1, image 1 of 3 Retina MacBook 2017 Trackpad Assembly Replacement, Disable Auto Boot: step 1, image 2 of 3 Retina MacBook 2017 Trackpad Assembly Replacement, Disable Auto Boot: step 1, image 3 of 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. Retina MacBook 2017 Trackpad Assembly Replacement, Unfasten the lower case: step 2, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. Retina MacBook 2017 Trackpad Assembly Replacement: step 3, image 1 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 3, image 2 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 3, image 3 of 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  4. Retina MacBook 2017 Trackpad Assembly Replacement: step 4, image 1 of 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  5. Retina MacBook 2017 Trackpad Assembly Replacement: step 5, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 5, image 2 of 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  6. Retina MacBook 2017 Trackpad Assembly Replacement: step 6, image 1 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 6, image 2 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 6, image 3 of 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  7. Retina MacBook 2017 Trackpad Assembly Replacement: step 7, image 1 of 1
    • Close the MacBook and carefully flip it upside-down.
  8. Retina MacBook 2017 Trackpad Assembly Replacement: step 8, image 1 of 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  9. Retina MacBook 2017 Trackpad Assembly Replacement: step 9, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 9, image 2 of 2
    Buy
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  10. Retina MacBook 2017 Trackpad Assembly Replacement: step 10, image 1 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 10, image 2 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 10, image 3 of 3
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  11. Retina MacBook 2017 Trackpad Assembly Replacement: step 11, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 11, image 2 of 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  12. Retina MacBook 2017 Trackpad Assembly Replacement: step 12, image 1 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 12, image 2 of 3 Retina MacBook 2017 Trackpad Assembly Replacement: step 12, image 3 of 3
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  13. Retina MacBook 2017 Trackpad Assembly Replacement: step 13, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
  14. Retina MacBook 2017 Trackpad Assembly Replacement: step 14, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 14, image 2 of 2
    Battery Blocker
    $3.99
    Buy
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  15. Retina MacBook 2017 Trackpad Assembly Replacement, Trackpad Assembly: step 15, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement, Trackpad Assembly: step 15, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad.
  16. Retina MacBook 2017 Trackpad Assembly Replacement: step 16, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 16, image 2 of 2
    • Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector.
  17. Retina MacBook 2017 Trackpad Assembly Replacement: step 17, image 1 of 2 Retina MacBook 2017 Trackpad Assembly Replacement: step 17, image 2 of 2
    • Gently pull the keyboard ribbon cable out of its slot in the frame.
  18. Retina MacBook 2017 Trackpad Assembly Replacement: step 18, image 1 of 1
    • Remove the five 2.5 mm T3 Torx screws securing the trackpad to the case.
  19. Retina MacBook 2017 Trackpad Assembly Replacement: step 19, image 1 of 1
    • Hinge open the display just slightly to free the trackpad assembly from the upper case, and remove the trackpad assembly.
    • Metal brackets on each side of the trackpad may fall away during removal. Be sure to position them as shown in the photo during reassembly.
6 other people completed this guide.
Tobias Isakeit
130,671 Reputation
189 Guides authored
2 Guide Comments
Why do you need to disconnect the audio jack and USB-C port?
Kyle Hampton - Reply
To make the guide longer :))
Chris Brown -
Past 24 Hours: 3
Past 7 Days: 90
Past 30 Days: 578
All Time: 10,810
