Retro-Bit Retro Duo Cartridge Doors Replacement
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: step 1, image 1 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: step 1, image 2 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: step 1, image 3 of 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement: step 2, image 3 of 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Cartridge Doors Replacement: step 3, image 3 of 3
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: step 4, image 1 of 2 Retro-Bit Retro Duo Cartridge Doors Replacement: step 4, image 2 of 2
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: step 5, image 1 of 2 Retro-Bit Retro Duo Cartridge Doors Replacement: step 5, image 2 of 2
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
Truong Vo
320 Reputation
3 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 608
