Retro-Bit Retro Duo Circuit Board Replacement
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 2, image 3 of 3
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 3, image 3 of 3
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
  4. Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 1 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 2 of 3 Retro-Bit Retro Duo Circuit Board Replacement: step 4, image 3 of 3
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
Truong Vo
320 Reputation
3 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
10 Guides authored
One Comment
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 2,434
