Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement
  1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): step 1, image 1 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): step 1, image 2 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): step 1, image 3 of 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 2, image 3 of 3
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  3. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: step 3, image 3 of 3
    • Carefully lift the circuit board from the controller case.
Evelyn
223 Reputation
2 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,012
