Retroid Pocket 3 LCD Screen Replacement
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 LCD Screen Replacement: step 2, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 2, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 2, image 3 of 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 LCD Screen Replacement: step 3, image 1 of 2 Retroid Pocket 3 LCD Screen Replacement: step 3, image 2 of 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 LCD Screen Replacement: step 4, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 4, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 4, image 3 of 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: step 5, image 1 of 1
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
  6. Retroid Pocket 3 LCD Screen Replacement: step 6, image 1 of 1
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
  7. Retroid Pocket 3 LCD Screen Replacement: step 7, image 1 of 1
    • Unclip and remove the one ribbon cable on the left.
  8. Retroid Pocket 3 LCD Screen Replacement: step 8, image 1 of 1
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
  9. Retroid Pocket 3 LCD Screen Replacement: step 9, image 1 of 2 Retroid Pocket 3 LCD Screen Replacement: step 9, image 2 of 2
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
  10. Retroid Pocket 3 LCD Screen Replacement: step 10, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 10, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 10, image 3 of 3
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: step 11, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: step 11, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement, Button Pad: step 11, image 3 of 3
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
  12. Retroid Pocket 3 LCD Screen Replacement: step 12, image 1 of 2 Retroid Pocket 3 LCD Screen Replacement: step 12, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
  13. Retroid Pocket 3 LCD Screen Replacement: step 13, image 1 of 2 Retroid Pocket 3 LCD Screen Replacement: step 13, image 2 of 2
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
  14. Retroid Pocket 3 LCD Screen Replacement: step 14, image 1 of 1
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
  15. Retroid Pocket 3 LCD Screen Replacement: step 15, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 15, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 15, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
  16. Retroid Pocket 3 LCD Screen Replacement: step 16, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 16, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 16, image 3 of 3
    • Carefully pry up the silicone button pad with a Spudger tool.
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: step 17, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: step 17, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement, Trigger Button: step 17, image 3 of 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
  18. Retroid Pocket 3 LCD Screen Replacement: step 18, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 18, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 18, image 3 of 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: step 19, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: step 19, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement, LCD Screen: step 19, image 3 of 3
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
  20. Retroid Pocket 3 LCD Screen Replacement: step 20, image 1 of 3 Retroid Pocket 3 LCD Screen Replacement: step 20, image 2 of 3 Retroid Pocket 3 LCD Screen Replacement: step 20, image 3 of 3
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
Troy
85 Reputation
1 Guide authored
1 Guide Comment
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - Reply
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 63
All Time: 1,843
