Retroid Pocket 3 Trigger Button Replacement
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: step 1, image 1 of 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Trigger Button Replacement: step 2, image 1 of 3 Retroid Pocket 3 Trigger Button Replacement: step 2, image 2 of 3 Retroid Pocket 3 Trigger Button Replacement: step 2, image 3 of 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Trigger Button Replacement: step 3, image 1 of 2 Retroid Pocket 3 Trigger Button Replacement: step 3, image 2 of 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Trigger Button Replacement: step 4, image 1 of 3 Retroid Pocket 3 Trigger Button Replacement: step 4, image 2 of 3 Retroid Pocket 3 Trigger Button Replacement: step 4, image 3 of 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: step 5, image 1 of 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: step 5, image 2 of 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: step 5, image 3 of 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
  6. Retroid Pocket 3 Trigger Button Replacement: step 6, image 1 of 3 Retroid Pocket 3 Trigger Button Replacement: step 6, image 2 of 3 Retroid Pocket 3 Trigger Button Replacement: step 6, image 3 of 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 87
All Time: 1,205
