Reverse Osmosis Filter Reservoir Pressure
  1. Reverse Osmosis Filter Reservoir Pressure, Disconnect the water supply: step 1, image 1 of 1
    • Disconnect the filter from the main water supply
    • Typically this is a needle valve
  2. Reverse Osmosis Filter Reservoir Pressure, Open the main water valve: step 2, image 1 of 1
    • Open the main valve to release the pressure from the reservoir/bladder.
    • Leave this open until you are ready to repressurize the reservoir
  3. Reverse Osmosis Filter Reservoir Pressure, Connect air pump to the reservoir: step 3, image 1 of 1
    • Remove the cap from the Schrader valve (or other) and connect an air pump
    • Most reservoirs have a standard Schrader valve
    • For a standard Schrader valve, connect a bicycle air pump to the valve stem
    • Use the air pump to (Gently!) force all of the water from the reservoir
    • Be careful to not over pressurize the reservoir/bladder! This may damage the filter!
    • (Gently!) pump your air pump as the water is drained from the reservoir
    • Continue (Gently!) pumping, to ensure all of the water is emptied from the reservoir.
    • Easy rule of thumb: if your pump has a built-in pressure gauge, generally avoid more than 10 to 20 PSI
  4. Reverse Osmosis Filter Reservoir Pressure, Close the output valve of the reservoir: step 5, image 1 of 1
    • Close off the output valve for the reservoir
    • For most RO unit reservoirs, this is a ball valve on the top of the reservoir
    • Release any over-pressure of the reservoir
    • The reverse end of most tire pressure gauges, a flathead screwdriver, or your car keys, are good tools to easily release pressure from a standard Schrader valve
  5. Reverse Osmosis Filter Reservoir Pressure, Repressurize the reservoir: step 7, image 1 of 1
    • Use your air pump to repressure the, now empty, reservoir
    • Most reservoirs operate between 5 and 8 PSI
    • Consult the owners manual for your specific filter to find the optimum operating pressure for the reservoir
  6. Reverse Osmosis Filter Reservoir Pressure, Repopen the reservoir: step 8, image 1 of 1
    • With the reservoir repressurized to the specified pressure, reopen the ball valve
    • Fin.
Your reverse osmosis (RO) water pressure reservoir/bladder should now be repressurized!
Daryl Metzler
723 Reputation
1 Guide authored
iFixit Member of iFixit
Staff
140 Members
18,086 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 546
