Revlon 473 Hair Dryer Switch Replacement
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: step 1, image 1 of 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: step 2, image 1 of 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: step 3, image 1 of 3 Revlon 473 Hair Dryer Switch Replacement: step 3, image 2 of 3 Revlon 473 Hair Dryer Switch Replacement: step 3, image 3 of 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: step 4, image 1 of 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: step 5, image 1 of 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: step 6, image 1 of 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Jessica Leyva
143 Reputation
5 Guides authored
Cal Poly, Team 1-5, Propen Fall 2012 Member of Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,866
