Revlon One-Step Hair Dryer Setting Dial Replacement
  1. Revlon One-Step Hair Dryer Setting Dial Replacement, Barrel: step 1, image 1 of 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 3 of 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 3 of 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: step 4, image 1 of 2 Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: step 4, image 2 of 2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Setting Dial Replacement: step 5, image 1 of 1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Setting Dial Replacement: step 6, image 1 of 1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 3 of 3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
  8. Revlon One-Step Hair Dryer Setting Dial Replacement, Setting Dial: step 8, image 1 of 1
    • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
2 other people completed this guide.
2 Guide Comments
Referring to step 4, how do you release the first part with the metal mesh inside from the body
Richard Funnell - Reply Share
This video shows very good how to dissamble the hairdryer. https://youtu.be/Qc-jcJbNQzE?si=wibfeCDW...
Tobi - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 56
All Time: 6,597
