Rexing V1P Plus Front Camera Replacement
  1. Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 1 of 3 Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 2 of 3 Rexing V1P Plus Front Camera Replacement, Front Camera: step 1, image 3 of 3
    • Begin by orienting the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Front Camera Replacement: step 2, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 2, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 2, image 3 of 3
    • Remove the back cover of the device and place it to the side.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Front Camera Replacement: step 3, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 3, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 3, image 3 of 3
    • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Front Camera Replacement: step 4, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 4, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 4, image 3 of 3
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Front Camera Replacement: step 5, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 5, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 5, image 3 of 3
    • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Front Camera Replacement: step 6, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 6, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 6, image 3 of 3
    • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Front Camera Replacement: step 7, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 7, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 7, image 3 of 3
    • Carefully peel back the adhesive material covering the ribbon cable connection.
  8. Rexing V1P Plus Front Camera Replacement: step 8, image 1 of 3 Rexing V1P Plus Front Camera Replacement: step 8, image 2 of 3 Rexing V1P Plus Front Camera Replacement: step 8, image 3 of 3
    • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
    • Once the connector is open, slide the ribbon cable out to remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 136
