Rexing V1P Plus Rear Camera Replacement
  1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 1 of 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 2 of 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: step 1, image 3 of 3
    • Begin by orienting the rear camera lens facing up.
    • Twist the adhesive mount surface parallel to the camera lens.
    • Pull the mounting ring axially away from the camera case.
  2. Rexing V1P Plus Rear Camera Replacement: step 2, image 1 of 3 Rexing V1P Plus Rear Camera Replacement: step 2, image 2 of 3 Rexing V1P Plus Rear Camera Replacement: step 2, image 3 of 3
    • Locate the small indentation on the camera case previously covered by the mounting ring.
    • Insert a spudger in the case seam and twist it to lever open the camera case.
    • Use the spudger to pry the case the rest of the way open.
    • Remove the top casing from the rear camera.
  3. Rexing V1P Plus Rear Camera Replacement: step 3, image 1 of 2 Rexing V1P Plus Rear Camera Replacement: step 3, image 2 of 2
    • Remove the camera and camera motherboard from the casing.
    • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
  4. Rexing V1P Plus Rear Camera Replacement: step 4, image 1 of 3 Rexing V1P Plus Rear Camera Replacement: step 4, image 2 of 3 Rexing V1P Plus Rear Camera Replacement: step 4, image 3 of 3
    • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
  5. Rexing V1P Plus Rear Camera Replacement: step 5, image 1 of 1
    • With the screws removed, the rear camera can be separated from the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 241
