Ricoh Shotmaster 130Z Shutter LED Replacement
  1. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: step 1, image 1 of 3 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: step 1, image 2 of 3 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: step 1, image 3 of 3
    • Using a Phillips J00 head remove the three 5mm screws on both left and right side of the camera as well as the one in back of it.
  2. Ricoh Shotmaster 130Z Shutter LED  Replacement: step 2, image 1 of 1
    • Using the same J00 phillips head screwdriver proceed to removing the remaining four 5mm screws on the bottom of the camera.
    • Last, using the same #00 phillips head screwdriver remove the two 0.6mm screws which are one on each side of the tripod connection dip.
  3. Ricoh Shotmaster 130Z Shutter LED  Replacement: step 3, image 1 of 2 Ricoh Shotmaster 130Z Shutter LED  Replacement: step 3, image 2 of 2
    • The case can now be removed from the camera.
    • Using a blue opening tool start by lifting the back part of the case right where the tripod dip is. Lift until the back part of the case is released and can be easily removed
    • Next, using the same opening tool lift and push by the battery compartment as shown in the second picture. Do this until the front part of the case is released and can be easily removed.
  4. Ricoh Shotmaster 130Z Shutter LED  Replacement: step 4, image 1 of 2 Ricoh Shotmaster 130Z Shutter LED  Replacement: step 4, image 2 of 2
    • The LED diode to be replaced can be found in the front of the camera next to the zooming lens.
    • Desolder the LED to remove it from the motherboard
anna carolina von einem
450 Reputation
4 Guides authored
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 342
