Ricoh Theta S Battery Replacement
  1. Ricoh Theta S Battery Replacement, Outer Case: step 1, image 1 of 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Battery Replacement: step 2, image 1 of 2 Ricoh Theta S Battery Replacement: step 2, image 2 of 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Battery Replacement: step 3, image 1 of 3 Ricoh Theta S Battery Replacement: step 3, image 2 of 3 Ricoh Theta S Battery Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Battery Replacement, Battery: step 4, image 1 of 2 Ricoh Theta S Battery Replacement, Battery: step 4, image 2 of 2
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  5. Ricoh Theta S Battery Replacement: step 5, image 1 of 2 Ricoh Theta S Battery Replacement: step 5, image 2 of 2
    • Lift the battery out of the device, beginning with the end closest to the camera.
7 other people completed this guide.
Bradley Sutton
737 Reputation
4 Guides authored
IUPUI, Team S3-G1, Harley Fall 2017 Member of IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Members
4 Guides authored
8 Comments
Nice demonstration, but if I can’t find a DB-110 replacement battery, I’m not sure if I would take the camera apart. If I find a replacement, this step-by-step demonstration will be very helpful.
Joel Brondos - Reply
The battery replacement for Ricoh Theta S is the Olympus battery model LI-92B.
It’s the perfect equivalent of the original Ricoh DB-110 battery. Tested personally.
Please don’t use any other similar battery or you risk to breaking the charge control circuit of the camera!!
Please note that you nullify the warranty, if the item is under coverage.
Franco - Reply
Do you have a good link for Olympus battery model LI-92B ?
Patrick D - Reply
It its very important to observe to remove the right side of the camera cover ! it is the side without button !!!
wkaemena - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 80
All Time: 10,227
