Ricoh Theta S Outer Case Replacement
  1. Ricoh Theta S Outer Case Replacement, Outer Case: step 1, image 1 of 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: step 2, image 1 of 2 Ricoh Theta S Outer Case Replacement: step 2, image 2 of 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: step 3, image 1 of 3 Ricoh Theta S Outer Case Replacement: step 3, image 2 of 3 Ricoh Theta S Outer Case Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Bradley Sutton
737 Reputation
4 Guides authored
IUPUI, Team S3-G1, Harley Fall 2017 Member of IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Members
4 Guides authored
One Comment
Where can find spare part case?
Thanks
Franco - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 2,174
