Ridgid Circular Saw R3205 Lower Blade Guard Replacement
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: step 1, image 1 of 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: step 1, image 2 of 2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 2, image 1 of 1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 3, image 1 of 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 3, image 2 of 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 3, image 3 of 3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: step 4, image 1 of 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: step 4, image 2 of 2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 5, image 1 of 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 5, image 2 of 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 5, image 3 of 3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 6, image 1 of 1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 7, image 1 of 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: step 7, image 2 of 2
    • Remove the lower blade guard after removing the washer.
3 other people completed this guide.
Joshua Caron
792 Reputation
5 Guides authored
One Comment
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 26
All Time: 2,045
