Ridgid GEN5X R8611506 Light Switch Replacement
  1. Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: step 1, image 1 of 2 Ridgid GEN5X R8611506 Light Switch Replacement, Outer Case: step 1, image 2 of 2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Light Switch Replacement: step 2, image 1 of 3 Ridgid GEN5X R8611506 Light Switch Replacement: step 2, image 2 of 3 Ridgid GEN5X R8611506 Light Switch Replacement: step 2, image 3 of 3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Light Switch Replacement: step 3, image 1 of 2 Ridgid GEN5X R8611506 Light Switch Replacement: step 3, image 2 of 2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Light Switch Replacement: step 4, image 1 of 2 Ridgid GEN5X R8611506 Light Switch Replacement: step 4, image 2 of 2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: step 5, image 1 of 2 Ridgid GEN5X R8611506 Light Switch Replacement, Light Switch: step 5, image 2 of 2
    • Locate the light switch near the bottom of the drill's inner components.
    • Gently remove the light switch from the casing.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 399
