Ridgid GEN5X R8653 Base Assembly Replacement
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: step 1, image 1 of 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: step 1, image 2 of 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: step 1, image 3 of 3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: step 2, image 1 of 3 Ridgid GEN5X R8653 Base Assembly Replacement: step 2, image 2 of 3 Ridgid GEN5X R8653 Base Assembly Replacement: step 2, image 3 of 3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 22
All Time: 245
