Ridgid JobMax R8620 Series E LED Grip Light Replacement
  1. Ridgid JobMax R8620 Series E LED Grip Light Replacement, LED Light: step 1, image 1 of 1
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 2, image 1 of 2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 2, image 2 of 2
    • Using a spudger or your fingers, remove the LED light from the groove in the handle.
  3. Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 3, image 1 of 2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 3, image 2 of 2
    • Carefully remove the motor as well as the main board from the drill cover.
  4. Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 4, image 1 of 2 Ridgid JobMax R8620 Series E LED Grip Light Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Find the corresponding position of the LED line on the motherboard. If necessary, use tweezers to pull it out and replace it.
Pengjian Zhou
557 Reputation
4 Guides authored
UC Davis, Team S20-G1, Lore Winter 2019 Member of UC Davis, Team S20-G1, Lore Winter 2019
UCD-LORE-W19S20G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 209
