Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement
  1. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement, LED Grip Light Switch: step 1, image 1 of 1
    • Pull the battery out of the case before opening the device.
    • Remove the nine 6mm screws on the drill cover using a Torx T10 screwdriver.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: step 2, image 1 of 1
    • Locate the LED grip light switch at the waist of the device.
  3. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: step 3, image 1 of 2 Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: step 3, image 2 of 2
    • Remove the plastic switch with the spring from the groove of the housing by hand.
    • Check to see if there are problems with the plastic switch or the spring.
  4. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: step 4, image 1 of 2 Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Find the slot on the motherboard along the wiring of the device.
    • Use tweezers to pull the plug out of the host slot.
Pengjian Zhou
557 Reputation
4 Guides authored
UC Davis, Team S20-G1, Lore Winter 2019 Member of UC Davis, Team S20-G1, Lore Winter 2019
UCD-LORE-W19S20G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 469
