Ridgid JobMax R8620 Series E Motor Replacement
  1. Ridgid JobMax R8620 Series E Motor Replacement, Motor: step 1, image 1 of 1
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E Motor Replacement: step 2, image 1 of 1
    • Using a spudger or your fingers, remove the LED light from the groove in the handle.
  3. Ridgid JobMax R8620 Series E Motor Replacement: step 3, image 1 of 2 Ridgid JobMax R8620 Series E Motor Replacement: step 3, image 2 of 2
    • Carefully remove the motor as well as the main board from the drill cover.
  4. Ridgid JobMax R8620 Series E Motor Replacement: step 4, image 1 of 2 Ridgid JobMax R8620 Series E Motor Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Find the black and red wires from the motor.
    • Remove the electrical tape using tweezers.
    • Using a soldering iron, desolder the black and red wires from the motor.
    • Refer to this helpful guide for tips on soldering/desoldering.
Pengjian Zhou
557 Reputation
4 Guides authored
UC Davis, Team S20-G1, Lore Winter 2019 Member of UC Davis, Team S20-G1, Lore Winter 2019
UCD-LORE-W19S20G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 803
