Ridgid R2601 Power Cord Replacement
  1. Ridgid R2601 Power Cord  Replacement, Top Cover: step 1, image 1 of 1
    • Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
  2. Ridgid R2601 Power Cord  Replacement: step 2, image 1 of 1
    • Pull off the top cover.
  3. Ridgid R2601 Power Cord  Replacement, Power Cord: step 3, image 1 of 2 Ridgid R2601 Power Cord  Replacement, Power Cord: step 3, image 2 of 2
    • Remove the two #6-19 x 15mm screws on the black retaining bracket using a Torx T15 screwdriver.
  4. Ridgid R2601 Power Cord  Replacement: step 4, image 1 of 1
    • Pop out and remove the black retaining bracket with your fingers.
  5. Ridgid R2601 Power Cord  Replacement: step 5, image 1 of 2 Ridgid R2601 Power Cord  Replacement: step 5, image 2 of 2
    • Loosen the screws in the white terminal block with a small flathead screwdriver. Note that you do not need to fully unscrew and remove them.
  6. Ridgid R2601 Power Cord  Replacement: step 6, image 1 of 1
    • Pull the wiring out from the white cover. The power cord can now be replaced by completing these steps in reverse.
Ellie Lott
461 Reputation
4 Guides authored
UC Davis, Team S20-G3, Lore Winter 2019 Member of UC Davis, Team S20-G3, Lore Winter 2019
UCD-LORE-W19S20G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 557
