Introduction
In order to replace most other parts in the sander, you must remove the top cover. All you will need is a T10 screwdriver. Make sure that the device is unplugged before following this guide.
Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
Almost done!
