Ridgid R2611 Switch Bracket Replacement
  1. Ridgid R2611 Switch Bracket Replacement, Switch Bracket: step 1, image 1 of 1
    • Remove the seven 2.5 mm screws on the top of the sander using the Torx T15 screwdriver.
  2. Ridgid R2611 Switch Bracket Replacement: step 2, image 1 of 1
    • Remove the top of the sander and put to the side.
  3. Ridgid R2611 Switch Bracket Replacement: step 3, image 1 of 1
    • Use the screwdriver to unscrew the two #6-19 X 5/8 in screws holding down the outlet cord.
  4. Ridgid R2611 Switch Bracket Replacement: step 4, image 1 of 1
    • Remove the cord from the handle.
  5. Ridgid R2611 Switch Bracket Replacement: step 5, image 1 of 1
    • Remove the outer plastic piece holding down the white and black wires.
  6. Ridgid R2611 Switch Bracket Replacement: step 6, image 1 of 1
    • Unplug the two connecting pieces that hold wires.
  7. Ridgid R2611 Switch Bracket Replacement: step 7, image 1 of 1
    • Using the screwdrivers, unscrew the four #6-19 X 5/8 in screws on rectangular block.
  8. Ridgid R2611 Switch Bracket Replacement: step 8, image 1 of 1
    • Remove the black and white wires by pulling out.
  9. Ridgid R2611 Switch Bracket Replacement: step 9, image 1 of 1
    • Put the screwdriver in the holes to release remaining two wires.
  10. Ridgid R2611 Switch Bracket Replacement: step 10, image 1 of 1
    • Remove the two remaining wires from switch, leaving the switch freed.
3 other people completed this guide.
Ana
384 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 298
