Ridgid R82005 Trigger Switch Replacement
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: step 1, image 1 of 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: step 2, image 1 of 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: step 3, image 1 of 3 Ridgid R82005 Trigger Switch Replacement: step 3, image 2 of 3 Ridgid R82005 Trigger Switch Replacement: step 3, image 3 of 3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: step 4, image 1 of 3 Ridgid R82005 Trigger Switch Replacement: step 4, image 2 of 3 Ridgid R82005 Trigger Switch Replacement: step 4, image 3 of 3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
2 other people completed this guide.
Alex Cominos
376 Reputation
2 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2019 Member of USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 435
