Rimless Glasses Temple Replacement
  1. Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 1 of 3 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 2 of 3 Rimless Glasses Temple Replacement, Rimless Glasses Temple Replacement: step 1, image 3 of 3
    • Take the compression sleeves and insert them into the outer lens holes with the pins facing out.
  2. Rimless Glasses Temple Replacement: step 2, image 1 of 2 Rimless Glasses Temple Replacement: step 2, image 2 of 2
    • Using the cutting head of the glasses plier, trim the compression sleeve pins down so that only 1 mm remains sticking out the front of the glasses.
    • Take a push pin and enlarge the holes of compression sleeves by gently inserting the pin into the holes.
  3. Rimless Glasses Temple Replacement: step 3, image 1 of 3 Rimless Glasses Temple Replacement: step 3, image 2 of 3 Rimless Glasses Temple Replacement: step 3, image 3 of 3
    • Insert the arm of the glasses into the enlarged holes of the compression sleeves.
    • Use a silhousette to gently press the arm from the top and tighten it to the glasses.
2 other people completed this guide.
2 Comments
This is very good if the frame arm just fell off of the lens, but it doesn't tell how to remove a broken frame arm from the lens—ie, how to get the compression sleeve off of the broken arm without damaging the lens.
JM MJ - Reply
for new lenses what are the hole centres for 2 pin please?
hoare - Reply
Past 24 Hours: 12
Past 7 Days: 71
Past 30 Days: 326
All Time: 10,335
