Ring Video Doorbell Housing Replacement
  1. Ring Video Doorbell Housing Replacement, Housing: step 1, image 1 of 3 Ring Video Doorbell Housing Replacement, Housing: step 1, image 2 of 3 Ring Video Doorbell Housing Replacement, Housing: step 1, image 3 of 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Housing Replacement: step 2, image 1 of 3 Ring Video Doorbell Housing Replacement: step 2, image 2 of 3 Ring Video Doorbell Housing Replacement: step 2, image 3 of 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell Housing Replacement: step 3, image 1 of 3 Ring Video Doorbell Housing Replacement: step 3, image 2 of 3 Ring Video Doorbell Housing Replacement: step 3, image 3 of 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell Housing Replacement: step 4, image 1 of 1
    • Remove the plastic film using the Plastic Tool Opener.
3 other people completed this guide.
Abdulrahman
685 Reputation
3 Guides authored
USF Tampa, Team S11-G5, Cheng Spring 2018 Member of USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Members
10 Guides authored
One Comment
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Charlie Adamson - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 34
All Time: 3,168
