Ring Video Doorbell Pro Speaker Replacement
  1. Ring Video Doorbell Pro Speaker Replacement, Housing: step 1, image 1 of 1
    • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
  2. Ring Video Doorbell Pro Speaker Replacement: step 2, image 1 of 3 Ring Video Doorbell Pro Speaker Replacement: step 2, image 2 of 3 Ring Video Doorbell Pro Speaker Replacement: step 2, image 3 of 3
    • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
  3. Ring Video Doorbell Pro Speaker Replacement: step 3, image 1 of 1
    • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
  4. Ring Video Doorbell Pro Speaker Replacement: step 4, image 1 of 2 Ring Video Doorbell Pro Speaker Replacement: step 4, image 2 of 2
    • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
  5. Ring Video Doorbell Pro Speaker Replacement: step 5, image 1 of 1
    • Remove the front of the device from the back plate.
  6. Ring Video Doorbell Pro Speaker Replacement, Speaker: step 6, image 1 of 1
    • With the Video Doorbell Pro opened up the speaker is exposed.
  7. Ring Video Doorbell Pro Speaker Replacement: step 7, image 1 of 1
    • Remove this 5.25 mm screw.
  8. Ring Video Doorbell Pro Speaker Replacement: step 8, image 1 of 1
    • Remove this wire connection by gently prying it off with a plastic pry tool.
  9. Ring Video Doorbell Pro Speaker Replacement: step 9, image 1 of 1
    • Remove the speaker from the device.
    What is the model number of the speaker
    Sammy De Maertelaere - Reply
To reassemble your device, insert the new speaker and follow these instructions in reverse order.
6 other people completed this guide.
Jake Dixon
850 Reputation
4 Guides authored
IUPUI, Team S7-G4, Baechle Fall 2017 Member of IUPUI, Team S7-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G4
3 Members
5 Guides authored
8 Comments
Hi Jake. This looks brilliant - I would love to contact you directly as I have a further question about this. My member name is robinfeild, and my email is email is robinfeild@gmail.com.
Hope to hear from you!
Thanks
Robin
Robin Feild - Reply
Anyone happen to know where you can purchase the replacement speaker from?
John Clark - Reply
Where did you get a replacement speaker from?
Volodymyr Kazantsev - Reply
Sammy - Reply
I dismantled the speaker in mine having verified it was faulty by testing it with one from a standard Ring Doorbell, (It has the same connector but the housing is a different shape. Having cracked open the plastic housing of the speaker it has one of these inside (1w 8 Ohm Rectangular speaker 15*11*3.5mm) such as https://www.ebay.co.uk/itm/224485373996 a couple of drops of superglue and two dabs of solder, works like new.
cagedbat - Reply
Where did you get a replacement speaker from ?
pascal.gohin77 - Reply
Hi jake where did u get the speaker from? Can you send link please, need speaker for ring doorbell 3 plus!
pamela.morris32 - Reply
Where can I get this speaker replacement? Thanks for the support. LG☺️
Pit Klasner - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 39
All Time: 15,294
