Rival CM4015 Power Button Replacement
  1. Rival CM4015 Power Button Replacement, Base Plate: step 1, image 1 of 2 Rival CM4015 Power Button Replacement, Base Plate: step 1, image 2 of 2
    • Remove the three 16 mm tri-point screws from the base plate.
  2. Rival CM4015 Power Button Replacement: step 2, image 1 of 2 Rival CM4015 Power Button Replacement: step 2, image 2 of 2
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
  3. Rival CM4015 Power Button Replacement, Power Button: step 3, image 1 of 1
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
  4. Rival CM4015 Power Button Replacement: step 4, image 1 of 2 Rival CM4015 Power Button Replacement: step 4, image 2 of 2
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
  5. Rival CM4015 Power Button Replacement: step 5, image 1 of 2 Rival CM4015 Power Button Replacement: step 5, image 2 of 2
    • Clean both the button and its slot before replacing the power button.
Connor Tustin
222 Reputation
2 Guides authored
Cal Poly, Team 10-6, Livingston Fall 2016 Member of Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 806
