Rival Mini Chopper MC-67BL Safety Latch Replacement
  1. Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: step 1, image 1 of 2 Rival Mini Chopper MC-67BL Safety Latch Replacement, Turning Gears: step 1, image 2 of 2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 2, image 1 of 1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 3, image 1 of 1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 4, image 1 of 1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 5, image 1 of 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: step 5, image 2 of 2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 6, image 1 of 1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 7, image 1 of 1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 8, image 1 of 3 Rival Mini Chopper MC-67BL Safety Latch Replacement: step 8, image 2 of 3 Rival Mini Chopper MC-67BL Safety Latch Replacement: step 8, image 3 of 3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Safety Latch Replacement, Power Button: step 9, image 1 of 1
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 10, image 1 of 1
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 11, image 1 of 1
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 12, image 1 of 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: step 12, image 2 of 2
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body and set it aside.
  13. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 13, image 1 of 2 Rival Mini Chopper MC-67BL Safety Latch Replacement: step 13, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
    • Next, turn the device upright and lift the upper casing from around the button gently.
  14. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 14, image 1 of 1
    • Remove the button by simply pulling it up.
    • Don't lose the spring under the button! Without it, the blender will not function.
  15. Rival Mini Chopper MC-67BL Safety Latch Replacement, Safety Latch: step 15, image 1 of 1
    • Use the Phillips #2 screwdriver to remove one 9.53-mm screw.
  16. Rival Mini Chopper MC-67BL Safety Latch Replacement: step 16, image 1 of 1
    • Remove the white latch by unhooking it from the spring wire and gently lifting straight up.
Roxanne
522 Reputation
4 Guides authored
Cal Poly, Team 4-29, Amido Fall 2013 Member of Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,469
